Get away with 35-40mm clearance above a Marantz PM6003?
I've got a PM6003 in a custom-made unit and want to add a Marantz tuner but as they are so big it will eat up the room at the top. It will sit on a CD6004 with just over an inch to the sides, no front on the unit, just enough at the back for the interconnects. Above, with a tuner in there as well, the front half of the amp would covered at a height of 35mm with the rear half going up more like 110mm (but also enclosed).
I know the official guidance is for 4-5 inches above an amp, but the PM6003 is not very powerful (45W per channel I think), and I probably won't use it at high volume very often. Will i get away with such tight clearances or will it power itself down the whole time? I can engineer some more space but it would be a lot of work.
Couple of other questions: I also didn't leave room for a plug to fit down the back of a shelf between the kit and the power socket (yes, I know, I really thought it through...) - is there any reason why I can't cut off the plugs and fit new ones in situ? Will it damage sound at all?
Finally, sorting out the cable mess - what's the minimum distance I should allow between data cables (speaker, interconnect, HDMI, aerial) and mains power cables? Can data cables be bunched together with impunity?
Thanks,
Chris
Al ears
4 to 5 inches clearance? Are they kidding? I don't have thsat much above my valve amp. You should be just fine with what you have as the PM6003 is never going to run hot enough to worry about.
MeanandGreen
149
69
18,670
I would check the guidelines in the Marantz manual for clearance, but you should be fine.
Keep signal cables a few inches from power cables, if they have to cross paths it should ideally be at 90 degree angles.
Fitting new mains plugs will make no difference what so ever.
