cliffster: 1 fatter
Some of Sony LCDs are fatter than plasmas. Once hung on a wall or kept on a TV stand, does it really matter? My plasma TV is only 6.3 cm thick.
Samsung PS50C6500 plasma TV is just 3.68 cm thick, whereas the Sony 46HX903 you like, is 6.7cm thick.
2 heavier
Again, does it matter? Are you going to lift it everyday? Still, let's compare a 46-inch TV. Panasonic 46G20 weighs 27kg while Sony 46HX903 weighs 30.2kg without stand. And the Samsung 50-inch plasma (PS50C6500)? A mere 24.5kg.
3 noisier
Not really. Some of the plasmas buzz a bit. I can't hear my plasma buzzing.
4 hotter
In my 15 months of use of my plasma, I never noticed it becoming hot.
5 use greater amounts of power
Yes, around £10 per annum extra power than an LCD.
6 have more reflective glass screens
Yes, their glass screens tend to be reflective. Just change the angle of the screen by just a bit to overcome this issue.
7 tend to suffer from phosphor trailing
Extremely rare among newer plasmas. I haven't noticed any in mine.
8 tend to suffer from screen burn
Again, not an issue among newer plasmas. Only 1 LG model & a Samsung model in the current lineup temporarily retain images. Otherwise, this has been overcome.
Have you considered these points about plasmas' advantages over LCDs?
1) Better blacks - great for shadow details & dark scene, and for "cinema quality" experience.
2) Better motion handling inherently with superior response times - Does not require artificial processors like 200Hz etc. & great for watching sports & playing games. LCDs tend to suffer from motion judder a bit more than plasmas.
3) Wider angle of viewing - Although newer LCDs are overcoming this problem, plasmas have a wider off axis viewing.
4) Colour accuracy - Plasmas tend to exhibit colours more accurately than LCDs .This is a personal preference, as many people prefer the oversaturated colours of LCD. Also depends on lighting.
The best TV ever to be made is a plasma (Pioneer Kuro) - this has been endorsed by all the reviews of this TV. It's yet to be surpassed convincingly, even after 2 years. You can check its reviews online.
Have you checked
this news?
All I'm saying is, choose a TV regardless of technology. Just audition all TVs & pick which you feel has the best picture quality.
