OK, the shelf is up, here are a couple of pics:
It went up almost spot on horizontaly, I had to make a 3mm shim to allow for the wall out of plumb. Nice and tight, solid and all that. Wood colour issue was solved with a mix of waxes and a final coat of a red mahogany wax.
:? . . . setting everything back as it was, apart from the re vamped cupboard/shelves that Hazel has decided she does not want, new item requird, more expence :wall:
Why did things not sound right, I could hear extra detail but the imageing was off, a little tweak here and there to the shelf helped, three board suport points instead of four made a big improvement, but I had to be honest, it was not doing it for me.
Bed time, 2am! . . . sleep on it . . . Fresh this morning, it had to be the cartridge, already reported as suspect, was I actualy hearing even more clearly its worn stylus. Removed the cartridge, had a look with a glass, it looked very sad? So, the new Benz was installed, £1000 worth of cartridge and no stylus gard
ray:
. . . All went OK, the old eyes are not what they were; time and care, the new high position for the TT helps a lot . . . but it still made the old back twinge a little.
Instant improvement, better, not perfect but in the right direction. Started tweaking, as you do, considering its straight out of the box, the Benz was suprisingly good . . . now with just a couple of hours playing time, it is obviously bedding in, its not going to take long to log up the required 40 hours, then I can finaly set it to my liking, doing well at present . . . :cheers:
All I have to do now is get the Sumiko looked at and order the 'Plank Wood Cupboard' Hazel likes to go under the TT suport . . . relax, enjoy the music.
CJSF
