Foobar2000 - User Interface Gallery
I've also got Channel Spectrum Panel Visualisation working. The dll is available here.
Again, this is available from the Columns UI Preferences by adding a panel to your UI by selecting the appropriate visualisation. It's more groovy than the default sprectrum analyser.....but I don't really know what you're after.
Please remember you need to restart foobar whenever you place a new dll into the component folder.
Had a look at that Channel Spectrum Panel Visualisation, interesting.
I had already seen and used the the Columns UI Spectrum Analyser but it is not exactly like the Default version which is a shame.
I have the Schpeck Winamp plugin but I don't really want to install Winamp in order to use G-Force.
Just having a play with it at the moment- the missus like itunes interface and being able to control it with the remote control for the imon software for some reason.
I on the other hand prefer the sound quality using the WASAPI
What a fantastic thread. Thanks PJPro, and thanks especially to your primer on setting up the UI within Foobar.
I've just migrated back from using a Mac with iTunes to a PC running XP and Foobar and am currently evaluating the differences between using ASIO or Kernel Streaming (they do sound rather different to me), and now that I can navigate my library in Foobar like I could in iTunes, I have no reason to go back.
This makes me very happy.
A bit more tweaking and this is what I've ended up with:
Foobar is now feeding my DacMagic a 44.1kHz stream courtesy of Asio4all (you can just make out the little green icon in the Taskbar), and sounding splendid.
Nice one tractorboy.
How did you manage to tweak Chronflow to set the background album art much further back than the currently playing album?
It's not a tweak so much as just selecting a different option:
Preferences/Display/Chronflow - there should be tabs including Cover Display. On this there is a drop down selection called Saved Configurations. The one that I use is called Old Default. Some of the others are quite fun too, if not always so practical.
Thanks for that....I haven't really looked into the detail of Chronflow config. Of course, with your tip, I couldn't help myself. I had to tweak the code. I created a new configuration called PJPro and did some messing.
I've pushed the background album art back a little and reduced it's size (in comparison to the playing album), reduced the eye position so that the playing album art is square and increased the number of albums on dislay at once.
Cool!
PJ , Just bought a DACMAGIC to pursue digital further, since I Am anti-apple (Dont really know why!) saw your post & thought would go with EAC Flac/ Foobar , following your UI Primer (great post BTW) and adopted your file structure since starting from scratch.
Have got it setup fine so far with the exception of the Album art at the top , NG Playlist art shows but not above (artist displays but no picture)
Its obviously something very stupid and obvious but one of those ones where I could look for hours and not spot error .. Any ideas ? If not will leave it a day or so then recheck maybe spot it then.
kena:
Do you mean that Chronflow isn't displaying the album art? If so, the UI Primer thread does attempt to explain what you need to put into the Sources.
If you can tell me what you have put into the Sources and can provide a filepath to one of your images, I might be able to help.
Incidentally, you can find the Sources using
File | Preferences - Prefences dialog appears.
In the tree, expand the Display node.
Select Chronflow.
Click the Album Source tab.
The Sources textbox is towards the bottom of the panel.
PJ
D:Kens DcumentsKens Music Files%artist%%date% %album%%album%.jpg
As I said could look at it for ages.. Cant spell/type after a couple of Buds
Mine is...
D:CD archiveArtwork%album%.jpg
Where 'CD archive' is the folder where I store all my music and 'Artwork' is a subfolder which contains the pictures. I found this to be a lot easier than trying to store the album art in the individual album folders, for various reasons. e.g. non-standard file paths due to things like 2-disc albums.
I need my images to have the exact same name as the album for this to work (although I think we established earlier on PJP's setup that isn't necessary...
Yeah thats a good idea , since im starting from scratch its not a pain to change - Ill be watching Glastonbury I suppose till 2 am so depends how many beers I have!!
Hi everyone, I'm a fellow Foobar convert thanks to PjPro's instructions. While we're on the subject of Chronflow, I have almost all my album art embedded in the id3 tags (I think!). I don't have a seperate jpg for each album cover, unless itunes hides them somewhere. For some reason some of them show up in Foobar but others don't, anyone have any ideas why this might be? I don't know how i can instruct Chronflow to look for the album art if I can't find it myself, but since I can see it in itunes I know it must be there somewhere! Any help would be appreciated.
kena:
PJ
Does the folder "Kens Dcuments" really exist or is that just a typo?
Cowps:Hi everyone, I'm a fellow Foobar convert thanks to PjPro's instructions. While we're on the subject of Chronflow, I have almost all my album art embedded in the id3 tags (I think!). I don't have a seperate jpg for each album cover, unless itunes hides them somewhere. For some reason some of them show up in Foobar but others don't, anyone have any ideas why this might be? I don't know how i can instruct Chronflow to look for the album art if I can't find it myself, but since I can see it in itunes I know it must be there somewhere! Any help would be appreciated.
I'm not sure that Chronflow can extract album art from music files (someone please correct me if I'm wrong).
If you look at the Sources textbox you should be able to discover where your album art is. Remember, Chronflow tries to find the album art using the tags specified in the Sources textbox.
Clearly, for all of this to work, you need to be reasonably consistent in the way you file your album art away. You are able to specify more than one way for Chronflow to lookup album art by placing a number of paths in the Sources textbox. I had to do this for music which is filed under Various Artists. You know the sort of thing......Ladies Sing the Blues.
I'd recommend that you try to find your album art and use the same approach as tractorboy.....with all your album art in a single folder. If you do this, you can hard code the path and simply have Chronflow look for the album tag. So, something like this...
My own preference is to have closely associated files all in the same place....within my Led Zepplin IV folder, I have the music files, the album art and the EAC rip reports. If I were to download lyrics, I'd put them in the same folder. Incidentally, you can play the lyrics back to the music in foobar2000.....I have experimented but it seemed a little pointless.
tractorboy:
[snip].... non-standard file paths due to things like 2-disc albums....[snip]
There is no concept of 2 disc albums in my collection. That is a limitation of the media which is irrelevant once the music has been ripped.
PJPro:kena:
PJ
Only noticed typo when I cut/paste info for u (that could have taken ages to spot) , sorted now but do have a couple of albums which don't display art , i.e The View Which *** ? , shows in playlist but not in library(copy of image in album dir & also seperate Artwork dir ). needs further investigation but presumably related to title "?" Maybe using your recent automatic post will resolve.
I had just downloaded run_dll / autodownloader with idea of doing it automatically but since i'm more Network than scripting it would have definately been "work in progress"
kena:PJPro:kena:
PJ
Also check out the tags within the music files. Remember, they need to be exactly right. I remember having a problem with The Prodigy. The tag said Prodigy but the album art, etc was under The Prodigy.
kena:
Not sure I fully understand what you're saying here but if you get any problems with foo_run or albumartdownloader xui I'll help you out where I can. Please post any issues in the other thread....cos it'll help out others who follow you.
Sorted problem was with characters that can't be in filename i.e. The Cure 4:13 Dream , GP/Grievous Angel - Re-Ripped in EAC using "-" Cheers.. AlbumArt UI working as well cheers PJ
kena:Sorted problem was with characters that can't be in filename i.e. The Cure 4:13 Dream , GP/Grievous Angel - Re-Ripped in EAC using "-" Cheers.. AlbumArt UI working as well cheers PJ
You are able to change the value of the tags using foobar. Just right click the music track and select properties and change as required. You can change whole albums at a time by selecting multiple tracks and then right clicking. Still, reripping also works....and it's a result that you've got everything's working.
What do you think of Album Art Downloader XUI?
It great tho only just set it up and tested a few times - Have ripped about 25 CD's now for test - Just need my 20 metre Ethernet to run via attic from PC to living room to resolve playback issues and hopefully sorted .
PJ - Started to have a play with Foobar heres what i've got so far many thanks to you for your advice / primer .
