Hi there,
I was wondering if anyone could please give me some advise on choosing floorstander speakers to go with my current set up.
My system currently is:
Innuos Zenith music server - Chord Hugo TT - Bryston 4B 3
Now I want to find a stereo pair of loudspeakers to put on the end of all that.
My room dimensions are: 4.84 metres wide, 3.62 metres deep and 2.34 meters high.
That is the main section of the room but there is another bit which contains my sofa.
The extended section is: 2.89m x 1.15m x 2.34m.
The speakers will have to be around 2 meters apart with the listening "sweet spot" around 3 meters from the speakers.
One speaker will be a tad too close to a corner. I reckon that (depending on the size of the speaker) I can acheive a max distance of 45cm from the side wall to the acoustic centre of the speaker/driver.
Both speakers will be a max distance of 50cm from the rear wall to the REAR of the speaker cabinet. (again this depends on speaker size)
My music is the usual "bit of everything". I stream from Qobuz and rip CD's onto my server and I also occasionally download hi res onto the server.
I tend to listen to a bit of pop and rock, some jazz a bit of classical, anything that is recorded well.
Natural sounding vocals and instruments are most important to me. Tonal balance is very important too.
I generally prefer a bit of warmth but also like transparancy and sound stage depth.
I would want the system to go down to at least 40Hz (in room)
Im thinking along the lines of a 2 or 3 way floorstander up to the 7k price range.
Any advice or shared experiences woud be appreciated.
And yes of course I know that i need to listen to some options.
I have already listened to a couple of contenders.
