Floor Standing Speakers
mancub
I have a Linn LP12/Naim Pre/Power amp and Rega Ela's
Looking to upgrade speakers, was looking at Kudos Titans. Any other alternative
Room is 14Ft x 13ft
Thanks in advance
Room is 14Ft x 13ft
Thanks in advance
Welcome to the forum.
Presumably you mean the 606's? The Titans were not cheap and may be too much for a room of that size. There are plenty of alternatives but you are going to have to audition for yourself so might be an idea to tell us what you can get to audition.
smaller Spendor or the Neats already mentioned might be a place to start.
What sort of budget do you have?
Reactions: mancub
twinkletoes
197
134
770
I had really good results with Revel and suppose you should look at Focal these days as they own the brand (naim) and use them to develop all their speakers these days. So you'd expect them to match though haven't tried it myself.
Reactions: mancub and Al ears
mancub
What sort of budget do you havew?
Hi, Thanks. You might be right. Titans may be expensive and a bit too big. Will check out Neats and Wharfadale Diamonds. Budget around £1000 but could stretch to £1500
Presumably you mean to buy second-hand then?
That does make auditioning tricky.
Sort of makes me wonder why you mentioned Kudos Titans in the first place as your not going to find any for that budget.
ASK THE COMMUNITY
