Flat Speaker Cables & Plugs for Jamo 102HCS5 5.1 Set
Would be very grateful for any flat speaker cable recommendations for these speakers, as well as suitable plugs/pin terminations. The speaker cable ports look particularly small on these Jamos, so wondering if the cables have to be bare wire on the speaker end?
Thanks.
Arj:
Thanks.
You need to use bare wire to connect to the Jamo speakers. I would go with QED micro speaker cable.
Thanks Gerrardasnails. Funny that, I was about to order some of that very same QED Micro cabling. It is hard to come by out here (Spain)-just wondering on the off chance if you knew what the circumference of each single cable was and its combined height? I ask this as it is impossible to find a sample of it where I live-have cabling/space issues so need to find a suitable thin/flat cable without sacrificing performance.
Cheers.
HI, I HAVE THIS CABLE CONNECTED TO MY SAME SPEAKERS AND I AM VERY HAPPY WITH PERFORMANCE,DIAMATER OF CABLE IS 6mm BY 3mm.
I use Ixos 233 flat cable for my rear cable runs. It has an adhesive backing and can be painted over.
