- Oct 4, 2015
- 10
- 0
- 0
So is Flac really that much better than high quality Mp3 file ?
What difference do you hear if anything.
What do you use iTunes ?
I'm not sure..I did a test on internet...guessed first one wrong then the others mostly right..mp3 v flac but I think well recorded cd easily wins...what I found was the mp3 sounded better initially but upon closer listening the flac had more going on..then it was easier to distinguish between the two...on my main kit I would heard difference more clearly..but put both through a good dac? That would be interesting..a mp3 into Cyrus dac x? My mate did this...very nice sound..poor mp3 gets such a drubbing, through good dac? Shines..no drubalwaysbeblue1 said:So is Flac really that much better than high quality Mp3 file ?
shadders said:Hi,
there is no difference between FLAC (free lossless audio codec) and CD. You can convert between FLAC and CD with no loss of information.
Regards,
Shadders.
davedotco said:shadders said:Hi,
Regards,
Shadders.
If the streamed signal sounds significantly different from a CD, then you are doing the streaming wrong.
Usually as simple as a level mismatch or incorrect settings.
no difference between? They do sound different albeit kit dependent..so is the difference the kit?shadders said:Hi,
Regards,
Shadders.
mp3 sounds good through good equipment and what's interesting is even though things are left out (inaudible or not?) it's a very persuasive sound, and can make some classical pieces that drone on a bit quite zippy!..me and my mate played some stuff back to back mp3 and cd...and if no critical listening involved? Mp3s sound great!abacus said:FLAC is a lossless format, therefore it will be a 100% match to whatever it was ripped from, unless it was dodgy ripping software.
MP3 removes information that you cannot hear, so as to make the file smaller, however once taken away it cannot be put back, hence for archiving (And for future use) always use FLAC.
As to whether you can tell the difference, then this will be totally dependent on your system and ears.
I try to avoid iTunes as while it works seamlessly with other Apple products, it can be a pain in the backside if using other equipment.
Hope this helps
Bill
tonky said:But for critical listening ...
DomCheetham said:chebby said:everything is ripped in 320k AAC VBR
Hi chebby, how can it be 320k and VBR. Sorry to nit pick.
chebby said:tonky said:But for critical listening ...
Yeah, what is that exactly?
Is it 'dad-dancing' around the room until embarassed into ceasing by laughing/pointing wife or daughters?
Is it performing on 'air' guitar/drums/saxophone/baton until - again - caught out by cackling female and posted on facebook as 'sad git'?!
Is it listening to a brilliant drama/book/comedy/documentry and being fully absorbed?
Or is it that Linn/Naim 'thing' where you stare at the hi-fi intently, from a position calculated with precise trigonometry, without daring to move your head but tapping your toes?
(Not feet mind you. They must stay still. Only toes may be tapped if exuberance demands it.)
OK. Just joking about the 'critical listening' thing. I prefer cheerful/happy/frivolous/relaxed listening.
chebby said:DomCheetham said:chebby said:everything is ripped in 320k AAC VBR
Those are the settings selected.
Nit pick away with the guys at Apple.
(And yes, I know what you mean but it doesn't bother me.)
DomCheetham said:With AAC CBR there is a 512Kbps output, which creates files at FLAC size.
TomSawyer said:DomCheetham said:With AAC CBR there is a 512Kbps output, which creates files at FLAC size.
Happy to be proven wrong, but doesn't 512kbps only apply to multi-channel use with 320kbps being the maximum for stereo. Also, as lossless has the same audio bitrate as CD, which (again, happy to be proven wrong) would be 2 channels at 16 bits and 44.1kHz = 1,411.2kbps - still leaves a fair bit of compression at 512k. I would have thought ALAC was the codec of choice for anyone with an Apple orientation looking for FLAC sized files.
