FLAC player?
pjboag
8
Can anyone recommend a good media player for Android that plays lossless files. The media player on my HTC Incredible S doesn't play FLAC or Apple Lossless and I'm starting to move in that direction for my digital music at home. It would save ripping CDs twice!
pjboag
8
The_Lhc said:
Poweramp.
Many thanks 'The Lhc'
Poweramp works a treat. Will quite happily stump up the £3 after the 2 week trial runs out. Right now time for a larger microSD card to store more lossless music on
d4v3pum4
40
I use Foobar2000 to batch convert FLAC to mp3 for storage on my ipod, phone, car memory stick etc. I don't see the point in using large file sizes for portable devices, particularly when the memory cards aren't that cheap.
A 16GB card costs only £13.99 http://www.amazon.co.uk/SanDisk-16GB-microSDHC-Memory-Card/dp/B002NTP06K/ref=sr_1_2?ie=UTF8&qid=1310191137&sr=8-2
& a 32Gb card costs £36.99: http://www.amazon.co.uk/SanDisk-SDSDQM-032G-microSDHC-32GB-Card/dp/B003HIWHN0/ref=pd_cp_computers_3
AnotherJoe
407
Depending on your droid - the flac files may only appear when browsing by folder - not in your media library, with song, artist etc.
If this is the case download 'Extended Media Scanner'.
This will add the flacs to the library view.
caesar44
89
I came across this one:
http://www.androidzoom.com/android_applications/media_and_video/player_ntjo.html I
It looks good, and its free.
