Help needed again....
I thought that my wall behind the dabbed plasterboard was concrete block. So I was going to use a core bit to remove the plasterboard, fill in the void with hardwall plaster, then when set, drill through the plaster and into the block and use a steel anchor bolt to create a solid fixing for my plasma wall bracket.
Anyone done this before on Thermalite/Air blocks?
Thanks in advance.
Thanks in advance.
