Hi All
I would be grateful for your expert advice/thoughts. I have a budget of say £1k (ish) to spend on an AV Receiver and speaker package. The system would ideally be good for both the 'home cinema' and pretty decent for listening to audio (CD's/Itunes etc - Itunes streamed from IMAC to amp via Apple TV, or via plug in dock). I have read the reviews and it would appear the Denon AVR 1910 or 2310 would be a good choice, paired possibly with the Q-Acoustics 2000 cinema package. Would this set up be good for both purposes (Hi-Fi/home cinema)?
I went to Richer Sounds and listened to an Onkyo system with some Mordaunt Short speakers which was nice, but a £5K+ package which is more than I want to spend for a kick off system. They recommended for my budget the Denon AVR 1910, a pair of Mordaunt Short Aviano 1's for the front, Alumni 2's for the rear, an Alumni 5 for the centre and a sub for about £150.
So, to the experts, which would you say is better for a room 4.5 metres long by approx 3 metres in depth? It would be used 30% for music and 70% for video. Would I be better with the Q-Acoustics package, or mixing speakers up as per the advice I received from the salesman? They didn't have either system set up for me to listen to, so rather than dive in and buy I thought I'd come away and think about it.
I used to have Technics Hi-Fi's (about £2k's worth) 15 years ago but haven't bought anything decent since that time. I have a couple of 40 - 50" plasma/LCD TV's and have now decided in one room (my study) I want to pair one with a decent all rounder for my listening/viewing purposes.
Apologies for the lengthy 1st post, but would be grateful for your advice. The MS speakers looked nice, but the reviews on What Hi-Fi's site have me leaning towards their expertise, and that leans we towards the all round abilities of the Q-Acoustics 2000 package.
Thoughts/opinions/advice very gratefully received. Doubtless I will continue to upgrade as time goes by, but a decent starting point would be great as it will keep my enthusiasm warmed towards this.
