Hi everyone. I would be grateful for some advice regarding positioning for room treatment panels for my home cinema. My priority is to enhance vocal clarity for movies. It will be a ‘work in progress’ starting with two panels on the side walls and a rear wall bass absorber. Is it better to place the sidewall panels at the first reflection points of the front surrounds or the center channel. The room will be used exclusively for cinema so 2 channel music is not a consideration.
Thank you in advance
