- Aug 10, 2019
- 2,556
- 5
- 0
Hey guys,
I am trying to update the firmware on my Philips 32PFL5605H LCD TV, I have found the update online but I am not sure how you place it on a USB stick. These are the instructions I found online :
Philips TV software upgrade with USB portable memory
Introduction
Philips offers software upgrade capability for your TV using USB portable memory.
After you have completed software upgrade, your TV will typically perform better.
What improvements are made depends on the upgrade software you are using as well as the software
your TV contained before the upgrade.
You can execute the software upgrade procedure yourself.
Be aware that the content of this document is addressing technical or software skilled users.
Preparing a portable memory for software upgrade
For the procedure you will require:
• A personal computer with web browsing capability.
• An archive utility that supports the ZIP-format (e.g. WinZip for Windows or StuffIt for Mac OS).
• A preferably empty USB memory stick.
Note: Only FAT/DOS-formatted portable memory is supported.
New software can be obtained from your dealer or can be downloaded from the
www.philips.com/support website:
(1) Go to www.philips.com/support using the web browser on your PC.
(2) Follow the procedure to find the information and the software related to your TV.
(3) Select the latest software upgrade file and download it to your PC.
(4) Decompress the ZIP-file and copy the file “autorun.upg” to the root directory of the USB portable
memory.
Note: Only use software upgrades that can be found on the www.philips.com/support web site :
I am not sure how I decompress the zip file and copy to root directory on a USB (or what it even means) and what does FAT/DOS memory mean? Sorry to be a pain but I just need some help!
Introduction
memory.
