Well took your guys advised and thanks for helping and you know who you are.
Sent the RSFX rears back to sevenoaks and moved my Alumni from were the were from behind the sofa:
http://img443.imageshack.us/i/p1010180e.jpg/
And put one in the corner on the window side and the other on the other side wall, they are 90 degrees beside me, but set slightly back about 5 degrees, and about 2 foot above my head......
WOW Position is everything, It finally feels like I am in the movie, and get really envovled, and the wife... Tech hater, says she cant belive the difference,
and she goes on to say... that will teach me for rushing to set everything up. [:S]
I got to say, that even though I have diamond 9.1 for fronts, and the NEW Dali Vokal for centre, i am not hearing any sort of tonal mis-match.
Just thought I would share, as I have been trying to upgrade and buy stuff to make everything sound better, but all I had to do is, move stuff around, and buy a better centre. and listen to people and look on THX and Dolby for the new best speaker position.
[Y]
[Y]
