Ex display TV
cball313
17
I was after a bit of advise regarding purchasing an ex display TV from a shop. The TV is an LED Samsung which when I checked they 'should' run for 100,000 hours with no problems. It's been on display in the store for about 9 months, probably on high settings. Can you see any issues buying this? The price is around £1500 cheaper than buying it new.
Also, does anyone know the warranty policy with ex display items? E.g. 1 year, 6 months etc.
cball313 said:
Normally its 5 years warranty from the likes of John Lewis and Currys. I bought an ex-display TV from John Lewis and I loved it. I would only buy it if you can return it if there is any problems though. Check for image retention too.
