Andrewjvt said:davedotco said:andyjm said:Benedict_Arnold said:A crossover connects a single pair of inputs to both woofers and tweeters. Clearly in the circuit diagram I posted you clearly see woofers and tweeters are NOT connected to the same input terminals and without jumpers all you would get from one pair of speaker wires is all bass / midrange or all treble. Might be semantics but the filters aren't crossovers. And from hands on practical experience from a pair of ProAc Studio 140s, a pair of Mordaunt Short Mezzo 6s and the wonderful (ahem) Klipsch Reference 42s I'm currently saddled with, unless the clips are in place, one pair of speaker wires gives all treble or all bass. The defence rests, m'lud.
Benedict, I am afraid I am struggling to see your point. With the jumpers in place, the Polk circuit you linked to is a normal crossover design, with the jumpers removed it has been separated into its two constituent parts, a low pass filter and a high pass filter.
Why anyone should want to separate the two parts of the circuit has never been clear to me.
I'm afraid that B_A does not undestand the basics. Ie a passive crossover being a device that splits the incoming signal into bandwidth limited sections to drive each drive unit, hence the silly suggestion that the individual speakers somehow sort it all out themselves.
Each 'filter' is a separate circuit that only connects to the other filters at the terminals of the speaker, if single wired or the amplifier if bi-wired.
This is absolutely basic stuff, if you don't understand it, best not to comment on it.
Why vertical bi amping sometimes does not yeld much improvement perhaps
Passive bi-amping, whether vertical or horizontal has minimal if any effect, other than on the wallet.
The expectation that 'doubling' the amplifier 'power' (at substantial cost) will improve the sound quality will of course convince many that bi-amping is better.
I can think of no technical reason why bi-amping is better and several as to why it is worse. I have never heard any benefits and to my knowledge, there are no convincing tests that show any.
