Elac speakers.
lazarus the yamaha will be fine see here http://fr.yamaha.com/fr/products/audio_visual/av_receivers_amps/rx_v1065_black_g/?mode=specs
many amps are rated for 4 ohm loads and yours is one dont be misled by some of the posts on this thread
one off .... never said it wont work, but to summarise the post:....
To conclude then : For conventional class AB amplifiers the use of 4 ohm speakers greatly increases amplifier heating compared to when using 8 ohm loads - even if the maximum output currents are kept the same by exercising restraint with the volume control.
dim span didnt mean anything bad just worried the op might be getting put off what sounds like a terrific setup
many fine speakers are 4 ohm and yes amps may run hotter but if there rated for 4 ohm theres nothing to worry about
also many 8 ohm speakers are actually around the 6 ohm mark and that doesnt cause problems with 8 ohm only rated amps
i have a pure class a amp which runs very hot because of the design and has done since day 1 currently going into 4 ohm speakers no problems
lazarus:Does Whathifi have an opinion on this?lazarus check with yamaha or your dealer too but honestly this is a nothing and not worth worrying about since your amp can be connected to both 4 and 8 ohm loads
they even quote the output going into 4 ohm loads so its fine
The dealer told me it's ok,Yamaha mention's that it is ok.Than it will be ok for me too!-)
thx for all the replies!
I quickly looked up ur receiver spec- it seems like it is one notch above my mid-range onkyo receiver. I would guess it wud be perfectly safe to drive ur speakers @ 4 ohms....jfyi
