Just wanted everyone to know that you can now get the EB acoustics eb2s again and just to say how good they are.these are one of the best speakers IV ever heard and at £799 they are an absolute bargain.they are quite large for a standmount speaker but the finish is exceptional.they are made in the same factory as some of the best British Speaker companies (spendor). When plugged in it takes about 5 seconds to hear how good these are. straight away the sound stage becomes larger (more open)and vocals become very realistic compared to my dynaudio's. Midrange is clear and very detailed as is most of the presentation on these.bass was a bit light but i change the jumper cables which made the bass a bit deeper but still with lots of detail.i put talking heads on and Snares snap with plenty of attack giving it great timeing.the detail on these are amazing so the separation is easy to hear.you could hear every instrument playing even with the effect that they had put on in the recording like reverb.to be honest they kill my dynaudio's in every way but i find they do lack the dynamics of the ATC scm11 which are £1200 and i think this is where the eb2s should be priced when you see and hear them.the EB acoustics eb2s should not be missed if you're looking for Speaker under a grand and you get a 30 day trial so no excuses.they are transparent so a reasonable good hifi will be needed and i felt they needed some power to get the best from them.apart from that These are a must audition.if you want to try these go to arcaydis web page.theres no waiting times anymore like last time now.once you order they will be there the next day
