After a recent house move, I'm contemplating some new speakers.
The rest of the system is;
Front-end : Roksan Radius 5.2 with Nima arm & Goldring 2200 cartridge / Squeezebox touch with QNAP server
Amp : Roksan Kandy K2
Cables : Van Den Hul BUT need to change as not quite long enough in new house (likely to go for Van Damme studio blue)
Position : Room approx 15ft square, hardwood floor, speakers either side of fireplace close to rear wall but well away from corners
Source material - Vinyl or FLAC;
Classic Rock - Genesis, Floyd, Yes, Rush, Bowie
Indie - Smiths, Midlake, John Grant
Folk - Fairport, John Martyn, Joni Mitchell
plus some jazz, reggae & classical ... pretty broad musical tastes!
I'm currently using a pair of Totem Arros bought on impulse via Ebay. Undoubtedly very fine speakers and they sound great with acoustic music (folk, classical & some jazz) but to my ears they have a hashness in the upper mid / treble when turned up a bit or with 'busier' rock material especially vocals and electric guitars. I personally find them hard work either during longer listening sessions or when they are cranked up a bit.
So, I'm thinking of changing them for either B&W CM5s or Dynaudio Excite X12s; I've heard both and really liked them (but not in an a/b comparisson - my closest Dynaudio dealer doesn't do B&W and vice versa). Both have good deep bass and very smooth top end - exactly the criteria I'm looking for. Whilst working at a session at Broadcasting House recently I noticed that the BBC are into Dynaudio in a big way!
If anyone has any experiences or thoughts to share then I would be very receptive. Ditto if you feel there are other speakers that I really should hear before making a decision by all means suggest away! : )
Budget is around £800 to include stands if required.
Thanks in advance for your input.
