DVD burnt from ITunes wont play on DVD player
tom2b
29
Any advice for a novice?
I have recorded a movie from I tunes onto onto a DVD-R, however this wont play on my toshiba sd-220eb.
any way round this?
tom2b
29
..via my desk top pc~a basic packard bell with dvd writer.the movie was downloaded via i tunes...i guess the recording format or disk type is one that the toshiba cant'read'..
f1only
278
Could it possibly be an MP4 Quicktime file? If it is you possibly need to convert it to dvd. If it is just a one off i would use DVDFab on a trail basis, it works fully for a month.
tom2b
29
F1~thank you for your post
I checked the'properties'for this file and it states'Protected MPEG-4 video file...does that help ?
f1only
278
I think you will have a few problems in that case trying to convert it to DVD. Can you not play the file from the pc to the tv, so avoiding copying it to DVD? I'm not so sure about MPEG4 files i've never used or tried copying/converting that sort of protected files. Non protected are easily done for me, I use Nero to convert them.
tom2b
29
.....that is not feasible,unfortunately .
This movie('Rise Up',by Luciano Blotta) also is not available on DVD(to the best of my knowledge),otherwise there would have been an easy way round this...
Thank you for your input
peter312
11
As far as I am aware, there is no simple way to burn a video that you have downloaded from iTunes onto a DVD, so that it plays on a standard DVD player. The copy protection prevents it.
John Duncan
2,034
30
19,720
Indeed, iTunes movies are copy protected so you can't burn them to DVD. You would have to buy some software that would explicitly - and illegally - allow you to do it, or you need to buy an Apple TV.
tom2b
29
...what grates tho is that I paid for this,its not like I downloaded this by'illicit means' :) ...but I guess that is another subject...
thank you guys for your input
