When I select the dts hd ma track on blu ray, my receiver (marantz sr5005) set in auto shows multichannel in. Why not dts hd ma?
professorhat said:HDMI is a digital standard, so couldn't be used to transmit an analogue signal.
naughty573 said:you probably have it set to PCM instead of bitstream - change this to bitstream as suggested by the poster up above and you should be sorted
MUSICRAFT said:Hi AlmaataKZ
At a guess if secondary audio is on then please switch to off.
All the best
Rick @ Musicraft
