- Aug 10, 2019
- 2,556
- 4
- 0
Hi my dream system is now all assembled with your advice it is now up and running however i cant help thinking that because i have gone down the good looks & good design route that it lacks punch somewhat. The system is mainly used for watching movies and is currently at 5.1 using the B&W MT30 package which utilises the PV1 subwoofer. I am driving all of this with a Yamaha RX V1800 amp/receiver and using the Denon 3930 DVD player all with QED reference HDMI interconnects and QED silver anniversary XT cabling so overall you could say i havent scrimped on any of my purchases, although i am impressed by the quality ive just got this niggling feeling that it aint running how it should be; could it be that: (a). either it needs tweaking to improve on the settings that i have inputted or (b). it needs some big floorstanders adding to it?? (c). I need to give in, wave my white flag, admit defeat and get a professional to come in and tweak it for me?? In terms of (a) above when deciding crossover points for the MT30 package the amp asked to turn the crossover dial on the sub all the way round to its maximum to let the amp do all the bass management, however in the B&W manual it says to leave it at centre/mid point. Which is correct and what should the crossover point be, i would of thought that B&W would have been the authority on this but then it is the AV receiver that is doing all the decoding. Could this scenario be the creator of my problem or do you have any other ideas on other settings i need to boost to correct this lack of punch i so desire?? In terms of (b) i am completely taken aback by the new monitor audio platinum series though im not sure how they would fare in a movie orientated application. Would these fit into this system or would they be too overpowering and dominate too much. Also this would make the system 7.1 but with 5 speakers at the front end of the room is this correct as i have no scope for re-positioning of other speakers as all wires are now hard wired though walls??? And finally if there are any other AV speakers that i may of overlooked possibly B&W then please let me know as i really wanna get this system running right once and for all.....im not frustrated at all....honest!!!! In terms of (c) please god dont let it be this otherwise ill have to start wearing quilted carpet slippers and eating quiche!! Many thanks...
