Here's the spec:gel said:As above. Thanks.
cheers mate. Does it work just the same?ellisdj said:spec is irrelevant - you just use one of these
gel said:Does it work just the same?
Yeah, but I don't want to buy one from Hong Kong Wan do I? *smile*spiny norman said:gel said:Does it work just the same?
Yes, just like one of these
but £46.18 more expensive.
gel said:Yeah, but I don't want to buy one from Hong Kong Wan do I? *smile*
He is one of the sellers on Amazon.spiny norman said:gel said:Yeah, but I don't want to buy one from Hong Kong Wan do I? *smile*
Who or where is Hong Kong Wan?
OK, if you really want to splash out, go to your local Maplin and spend £3.89 on one of these
gel said:He is one of the sellers on Amazon.
No I haven't, I was just thinking of ways to improve my system.buzz_lightclick said:Have you bought another sub Gel? If so why?
