I see alot of youtube video about hifi and many private has an eq with a v shaped settings or loudness activated.
Personally i don't use loudness and i don't use the bass, treble tone controls, im lucky not to have bright speakers and speaker with a very good bass, i don't need to adjust the highs,lows and enjoy the difference there is when i listen to all from jazz to blues to pop,rock,heavy metal and electronic music
Some people can't hear the highs so good so they might need to raise it or buy bright speakers and if someone needs more bass they should get a subwoofer for deeper bass instead of louder bass so it starts to fall at lower hz,
Do you use an eq,tone controls, loudness?
If so why ?
Personally i don't think many on whathifi is 14 years old have big cerwin vegas and want as much bass as possible or just a thx system from logitech the gladly are playing extremly loud, even when it's distortion like hell.
Many of us just wants to have as good a sound as possible without having to worry about tone controls, loudness, most of us buy a system that sounds good with no adjustmets of the highs and lows, don't you think that when you have to adjust the highs,lows, that you don't have the perfect system for your needs, that there is something wrong with your system ?
If so why ?
