Hi there all. Ok my old set up which I loved but wanted to improve in terms of tighter bass and more dynamics as well as maybe more valve like treble/midrange:
At33ptg II
Nottingham Ace Space Deck
Pro-ject MM/MC phono preamp (£80 cheap tiny box)
JVC A-X01 amp
QED original cables
Cambridge Audio Azure Hi-Def phono interconnect (silver coated)(hasn't been beaten by any cables under £100 so far and I've had a few)
Wharfedale diamond 10.1 speakers
The sound was great but I only listen at low level. I rarely blast it and if I do as long as we can dance to it I'm not bothered, it is most important for it to sound good at low level critical listening levels similar to conversation volume. Is this why I don't need amazing kit to get good sound??
I have always wanted a Sugden a21a as my dad has one and I always liked it so this was my upgrade. This resulted is such rounded off treble I thought the amp must be faulty. Combined with the speakers it was way too smooth. Basically agree with all a21 reviews. But no presence at all with this combo. Very high midrange. So I upgraded my phono pre amp to a Rega Fono MC which supposedly has slightly scooped mids. Well that is even worse in terms of treble!
So laid back it is horizontal until something happens in the upper midrange and then it shouts it at unreasonable volume compared to the rest. Probably due to lack of treble making me turn up the volume higher.
Anyway I couldn't afford proac 1sc so tried some proac studio 115's that fixed it but went too far and harsh at times so sold them pretty quickly and enjoyed the great bass of the wharfedales again but cannot get away with the subdued treble.
I have used other sources like streaming and it is all the same problem.
Therefore my title question and: Is this normal to find low level listening problematic or do I have to buy very expensive perfectly neutral speakers for hi end hifi to work? (By the way I don't use the tone controls or loudness on the JVC)
I'm thinking maybe the synergy of my old system balanced out to be perfect but introducing perfectly neutral/natural equipment is sending it all off.
I would like to get away from depending on an old cheap amp but I have tried a lot of amps now and it has always won out. What's going on??!
Is all this because we really need a smiley face Freq response for volumes around conversation level?
Re high end hifi, I assume all the "current capacity", "damping" and "difficult speaker loads" all really just apply to very loud listening and does not come in at low level listening.
At33ptg II
JVC A-X01 amp
QED original cables
