Discrete IR hex codes
does anyone know of a reliable site where i could find discrete IR hex codes for most of the current rotel models, i've searched thier website, but they don't have any availiable.
i have also been onto remotecentral.com but they only have a few models listed.
i've been banging my head on this for a while now, and would appreciate it if anyone could help me further...
the codes will be used for programming the philips pronto products...
thanks again
warrenatmad
kena
104
Does Remote central have a file for a similar Rotel model ? , the codes dont change much if at all between models and you could use the learning capability of the Pronto to add any ones missing, If nothing at all suitable you could post to Remote Central I've always found them pretty helpful and informative.
