[quote user="Andrew Everard"]
I should think the digital to analogue converters in the player are better than those in the receiver, so I'd use a stereo analogue interconnect from the player into the Front Left/Right sockets of the receiver's multichannel input, as this provides the most direct signal path through the amplification. Choose 'Multi Ch In' to listen to CD.
[/quote]
Can't agree with Andrew more here - I have both the optical and line connections hooked up between my 740C and denon amp and its bizarre how much better the cd player sounds (line). If I switch from analogue to digital on the amp id track, the mid range goes out the window, soundstage pretty much collapses and I switch back real quick.
I'll be pulling the plug on the optical line next time I'm back there - I just left it hooked up as it was the only way i could connect the old CD changer the 740C replaced and I was curious to hear how my amps DAC's went up against the 740C's - not good ; )
Just another thing I picked up on there Andrew - my analogue connections' going to the CD socket right now - you reckon I shuold switch to the multi-ch input on the 4306? or was the advice specific to Pim's amp?
