Al ears said:
keeper of the quays said:
skularatna said:
I'm using this on MM. But would like to try on MC. Firstly, will it support it or is the voltage of 1.6Mv too high for the aria. Next, if it will work, what switch settings should I use? The load impedance of the DL-110 is 160 ohms. I am not sure what the capacitance is.
My setup : cayin A50T integrated valve amp. Rega RP3 turntable, DL-110 cartridge, Monitor Audio Silver RX1 speakers and Rega Aria phono stage.
has your phono stage got a Mc output? I use a dl110..it's a nice cart..better than the horse! Lol..ps it's usually used in mm mode ..but in Mc mode it sounds very nice through my Linn turntable..very quiet player too through Mc mode...it will be fine through either..i used to use it mm mode but went over to Mc (i have a switch and separate outputs for mm and Mc on my ca 640p phono stage) it's plenty loud enough thru Mc for my hifi..
I'll bet it's loud enough sending 1.6mV through a moving coil stage.
Thanks for all the replies. With regards to impedance, there's load impedance and electrical impedance
Generating method: moving coil
Output voltage: 1.6mV
L/R sensitivity: within 1dB
L/R separation: more than 25dB
Electrical impedance: 160 ohms
Load resistance: more than 47kOhms
i am guessing I set the dip switches to match the load rather than Electrical impedance? Max possible switch setting is for 400ohms on the Aria. Can anyone advise?
