Ok, so I've put the Denon on the Gyro, this morning and set it up correctly, this time
No Inner Groove Distortion this time.
Here's the thing, though: I don't know if I like it.
It's definitely got some positive points:
1: cymbals sparkle and sound nice and light, as they should.
2: It's pretty detailed
But, that's about it really, for the positives. Here's what i'm not liking:
1: It's got a bit hard edge to vocals, occasionally slipping into sibilance territory.
2: it's lightweight. Compared to the Shure, it's bass is small, but a bit boomy at the same time, if that makes sense. It isn't tight and lacks the texture that the Shure has.
2a: I think this links in with the above, but rock and metal doesn't sound great. It has no punch or drive. With the Shure, rock and metal sounded better than i've ever heard it, but with the DENON it's uninvolving.
3: Although I've sorted the alignment out, the cartridge still hardens up during the last minute or so of a side. I've been told that this is down to the conical design having trouble tracking the inner grooves. Annoying.
It's an ok cartridge, but i'm sitting here listening and picking faults in the sound, whereas when I listened to the Shure on Saturday, I couldn't get enough of it and couldn't find any faults. I was putting on record after record, excited to hear how it sounded.
So, here's my question for you all: now I know what I want (and don't want) from a cartridge I'd like some suggestions. I don't mind if the suggestion is for MM or MC. Please only suggest carts that you've heard, though, not ones that the reviews say are right for me
Budget: £200 - £350.
This is what i'm after: super realistic vocals, detailed and a deep strong bass.
FD, I know we've spoken in the past about this, and the Micro ACE is still on my wish-list, but I don't reckon i'll be able to swing a £600 cart this year. I'm taking on a canvasser for work, next month, so funds are gonna be a bit stretched for a while. Defo one for the future, though.
