Hey all,
I'm quite inexperienced when it comes to headphones but recently as they was on a big sale I got a pair of Denon AH-D7100. I had a go on them with a laptop using a Asus Xonar U7 USB Soundcard and the sound quality was quite poor. I used to own a pair of AH-D5000 and the sound quality was excellent with it though I do consider I probably need a more expensive amp? The vocals are the worst with them not even being made audible within the song. I have used both a ipod and my onboard weaker sound card and these both sound good and the sound quality problems are not as present with these. I'm at a bit of a loss though I suspect it's due to the power required by them. I'm also having to use the smaller jack lead with the phones which is not as good quality from what I believe the box says would this make a difference if I was to get a 6.35mm to 3.5mm convertor?
Thanks a lot!
Thanks a lot!
