Hi all
My new Denon 4308 av reciever has worked well for about a week and has suddenly developed a green tint to all sources except the SkyHD?
Connections are as follows:
Amp to TV - 1.3HDMI
SkyHD to amp - 1.3HDMI & optical
HD-DVD to amp - 1.3HDMI
When on the set-up menu, even for skyHD there is a green tint present, yet when the SKYHD is switched on the picture is perfect, all the other sources display the green tint even when playing?
The TV is fine, I've checked it with all sources direct.
Has something inside the amp gone pop (RGB or similar) as it seems to disply red's and greens but no blues. When the wallpaper is set to blue it isn't blue.
Why will the SkyHD play ok, does the sky bypass some process in the amp that the other sources don't?
The shop where I bought it from have advised returning to Denon but I want to try to fix it first (if it can be) as the postage and the wait for a return (weeks!) does not fill me with joy after I've waited so long to get it.
Any ideas?
Camdxr
Amp to TV - 1.3HDMI
Any ideas?
Camdxr
