Garth Man:
He said that both used the same chip dude, just proves Ronald's point (on that seller anyway) oh well
I'm happy with it, just a bit annoying really as I wanted to go for the 2310 but was just shy of the budget last year. Differeent price now though, teh same as i paid for the 1910!!!! can't believe that
gel I shall look around my friend, and give you the heads up
, and vice versa please if you do
That is bad then. I would always check out the manufacturer's website in future for spec. Then again, I've seen Denon and Sony make mistakes before.
