first off this is all imo and people will agree/disagree
i think for the money the denon1910 is a must really (if you not buying into 3d). It has like my 1909 very easy to use interface, very good night mode,rename your inputs is always welcome. With movies and gaming i found the denon cant be touched for less than £500.
For 2channel stereo playback i find denon play it way to safe thats why after 5months i needed to set a hifi set-up as well.
The BR5's are a great choice,
pros£450 they seem to look the part and when friends/family walk in they do look alot more than £450,they are so easy to drive,they are small floorstanders and dont take over the room,they do go deep and hard to knock over.look so cool with grills off
cons,i think they need a 10inch gap all round or in my case with cd/spotify(no so with vinyl)can sound a touch boomy. I also think that they lack something you seem to get what you put in, where other speakers seem to have a bit of a character to them.(this might be classed as laid back and can be a pro). they look boring with grills on
i really think you will be happy if go for them unless you want major bass or the sound to jump out at you.they are very punchy and detailed.
so about the radio not got no background on that.
