utubecomment21 . said:I'm a DIY'er and I simply built a OB speakers using a pair of Morel tempo speakers, and they far outperform even the laughable Monitor Audio BX2 speakers which in comparison sound like they have a large Duvet over them.
£100 isn't going to buy you anything respectable. I'd sooner get on ebay buy a pair of Alpine SPG or SPR speakers, get a few slabs of MDF and you'll have speakers that will slay anything below the 300-400 euro range!
https://www.youtube.com/watch?v=C61lj3Jy-sI
Dragonsword said:utubecomment21 . said:I'm a DIY'er and I simply built a OB speakers using a pair of Morel tempo speakers, and they far outperform even the laughable Monitor Audio BX2 speakers which in comparison sound like they have a large Duvet over them.
What does MDF mean? And why would I buy those things? I don't know how to build my own speakers, I just need to buy ones that are already built. I was looking at Harman Kardon Soundsticks III, I tested them in a store and they sound good, but I've read their build quality sucks and people had them and it stopped working after a year. So do you know of any alternatives?
BigH said:Dragonsword said:utubecomment21 . said:I'm a DIY'er and I simply built a OB speakers using a pair of Morel tempo speakers, and they far outperform even the laughable Monitor Audio BX2 speakers which in comparison sound like they have a large Duvet over them.
Medium-density fibreboard. I don't think you will get much for a £100. Best to save up a bit more or buy some used ones.
Dragonsword said:BigH said:Dragonsword said:utubecomment21 . said:I'm a DIY'er and I simply built a OB speakers using a pair of Morel tempo speakers, and they far outperform even the laughable Monitor Audio BX2 speakers which in comparison sound like they have a large Duvet over them.
For how much money can I get decent/good speakers and which used ones would you recommend me? Also, do used speakers have a higher chance of dying than new ones?
Reijer said:Hi Dragonsword.
In Soest, by RMR, they have a new brand of actives, Steljes NS1 and NS3. Till june 1 they are at a discount. 139 instead of 199 euro's for the small ones.
Haven't heard them but they don't sell rubbish.
http://rmrsoundsystems.nl/steljes-audio-ns1
davedotco said:This is possibly the benchmark for inexpensive powered speakers in the 'mainstream'.
However they are, depending on your market, about twice your stated budget, so you have to think differently.
As pointed out above Thomann in germany will have plenty of options, take a look. spend as much as you can, at this level a few euros makes a lot of difference.
Dragonsword said:davedotco said:This is possibly the benchmark for inexpensive powered speakers in the 'mainstream'.
Stores in the Netherlands don't sell the Audio Engine 2, they only sell the Audio Engine A2+ which are 280 euro.
I just read somewhere the Audio Engine 2+ have bad highs, is that true?
Dragonsword said:Reijer said:Hi Dragonsword.
But they're only 100 - 20 kHz
Denon SC-N8 are 70 - 20kHz
Are the Steljes Audio N1 better than this
http://hificorner.nl/speakers/boekenplank/denon/boomboom-460-denon-sc-n8...
and this
http://hificorner.nl/speakers/home-cinema-speakers/satelliet/boston-acou...
BigH said:Dragonsword said:BigH said:Dragonsword said:utubecomment21 . said:I'm a DIY'er and I simply built a OB speakers using a pair of Morel tempo speakers, and they far outperform even the laughable Monitor Audio BX2 speakers which in comparison sound like they have a large Duvet over them.
http://hificorner.nl/speakers/boekenplank/q-acoustics/q-acoustics-2010i-walnoot
Are they better than the speakers I mentioned before and are they also better than the speakers on Thormann.de? The Q Acoustics 2020 have a good review on this site, but what about the 2010?
Dragonsword said:BigH said:Dragonsword said:BigH said:Dragonsword said:utubecomment21 . said:I'm a DIY'er and I simply built a OB speakers using a pair of Morel tempo speakers, and they far outperform even the laughable Monitor Audio BX2 speakers which in comparison sound like they have a large Duvet over them.
http://www.thomann.de/nl/behringer_ms40_multimedia_lautsprecher.htm
Why do they have holes in them? The woofers are 4 inch, are they big enough to have enough bass without a seperate subwoofer?
I've also seen these speakers
No I did not mean those, have a look at Mackie MC4, read the reviews. The holes are probably bass ports, not sure why 2 though. Will they be enough with sub, its it to you but for around £100 you are asking for too much. How are you going to position them? The Q Acoustics 2020 will need amplifier I believe.
Dragonsword said:Ok I can buy a subwoofer later. I am going to put them on my desk without speaker stands, next to my computer and monitor. I can buy an amplifier as well, if speakers and amplifier won't cost much more than 200 euro. The Mackie MC4 won't have enough bass so I probably won't buy them.
But I've seen a deal with Denon speakers and Marmitek Boom Boom amplifier, is it a good deal or not? I posted it in one of my earlier posts. I can get both of them for 188 euro. Also, what about the Dali Zensor Pico?
davedotco said:If you can find them in your market, take a look at the Acoustic Energy Aego M.
This is a full 2.1 system, subwoofer and satelites from a respected manufacturer, currently available for just £129 in the uk. Still over budget though.
Otherwise check out the Thomann website, plenty of choice from the likes of Alesis, Behringer, M-Audio, Samson etc. If you can stretch to €200, try the M-Audio BX5 or the ESI Active 05, much, much better than the cheaper options.
If these don't do it for you then I have no idea. Good luck.
Dragonsword said:davedotco said:If you can find them in your market, take a look at the Acoustic Energy Aego M.
I can't find the Acoustic Energy Aego M anywhere here. And I want to listen to the M-Audio BX5 before I purchase them, hmm I'll have to find a place where I can do so.
BigH said:Dragonsword said:davedotco said:If you can find them in your market, take a look at the Acoustic Energy Aego M.
Maybe here: http://www.dirkwitte.nl/95_m-audio
Dragonsword said:BigH said:Dragonsword said:davedotco said:If you can find them in your market, take a look at the Acoustic Energy Aego M.
But they cost 130 euro instead of 100 euro there. I have found 2 stores which sell them and I can return them within 14 days if they aren't good.
BigH said:Dragonsword said:BigH said:Dragonsword said:davedotco said:If you can find them in your market, take a look at the Acoustic Energy Aego M.
Thought you wanted to hear them first?
and this
