andyjm said:DocG said:Thanks for the input, guys. But let me rephrase my question: does one induce ground loops by using a separate radial circuit for the CDP, the amp, the settop box, the sat receiver etc? Is it better to use a common earth connection for all of them? Or is it of no importance whatsoever?
I might consider a mains regenerator (or balanced mains supply) should the mains appear to be very poor quality... but it is -- how shall I put this? -- not a priority at the moment.
Doc,
In an unbalanced system, the audio signal is referenced to ground. To make sure every device is using the same ground, it is usual to have ground carried from device to device using the screen on screened interconnects. If an 'earth loop' exists (more than one ground connection between two devices, taking a different route, then it is possible for current to flow along the loop, causing a noise voltage to develop between the two grounds. This noise voltage is mistaken for a signal by the amp, and amplified. In a domestic situation, induced mains is the most likely culprit and a ground loop is often characterised by mains hum.
In an ideal world, 'star point earthing' is used. A single point from which all signals are refenced and all earths come from. This is approximated in a modern system where the amp / AVR is earthed, and (usually) the other components are not earthed and rely on the amp / AVR as the star point.
As only the amp / AVR is usually earthed, your radial solution won't make any difference, but I would personally rather have all of the devices connected to the same supply, particularly as you have satellite / phone line connections which can generate high fault voltages in the case of lightning strikes or similar.
Are you sure every socket is being led back to the distribution board by a separate cable? That's a large amount of wire for no reason?
In my experience 'specialist' hi-fi equipment generally behaves as described by Andyjm above, it is the non hi-fi components thay cause the issue, TVs, satelite boxes and such. I f you go through the system logically this is not hard to work out.
There is no need to run multiple cables, a single run of twin and earth (30 amp 'cooker' cable ideally) hard wired to as many unswitched MK sockets as you need. Just make sure the earth at the fusebox end is sound.
