Hello all,
I'm after some advice please, i've finally decided what speaker package to buy after many auditions of the main contenders and the Dali package is the winner but i've got an issue with setting it up once i order it.
At present i have my Q Acoustics 7.1 set up configured so that my rears are on brackets and likewise for the centre speaker due to my rack having no space left on it to place the centre so my question is how would i go about mounting the centre and rears of the Dali Zensor 5 package?
I know the Zensor 1's have a bracket (of sorts) on the rear of the cabinet but it's just a keyhole style cut out at the top of the speaker so is this the best way of mounting the rears? The only issue with this solution is that the speakers are not easily directed and in my room i would ideally like something more directional such as a bracket so i can get them into the corner of the room and direct them easily so would a standard speaker bracket be a good solution for me?
I also need to mount the centre speaker to the wall so is there a bracket out there that would be suitable for this purpose as i simply don't have room on my stand as it's full of kit, i know the centre speaker is a bit of a beast so if anyone could recommend a suitable bracket i would be really grateful, same goes for the rears.
I would like to order the brackets in time for the speakers to arrive so i can set it up correctly as soon as i get them rather than wait but i can't seem to find the ideal bracket solution so any help would be really appreciated.
Many thanks in advance.
