Hi all
i have a pair of Dali Zensor 3's which I have ran off Pioneer amp and cheap (short) speaker cable. As part of moving things around I bought Cambridge Audio Ultra Micro speaker cable, thinking this better quality cable would be ok at 15m per speaker.
However, the sound level at this length is definitely quieter and needs more volume and i'm pretty sure the sound quality isn't as good at this length even with this cable (thoughts? My ears? Paranoid? Accurate? Or just quieter?)
15m is more than I need so could cut each cable down to 10-12m. Do you think this would make much difference to the quality using this cable?
my other option is to start going through walls which I may do, bringing it around the 5-6m mark in length
Whats people thoughts on this cable in general and the ideal speaker length?
I don't mind if I need to turn the volume up a bit but I feel the rich clarity sound is lacking
Thanks all
Thanks all
