insider9
QuestForThe13thNote said:What did you compare it on Insider ? We did a test of a node2 into my cyrus pre dac playing tidal masters mqa and tidal hi Fi, and it was the same. No discernible difference. I was umming and Aaring and it would have been bias to select one over the other. But the cyrus streamer playing tidal hi Fi cd streaming gave a fuller, bigger soundstage and was preferred in our bake-off of 4people. The node 2 used its analogue outs, so that may have accounted the difference in comparison to the cyrus because we were bypassing my cyrus dacs. But I’d expect the cyrus to beat the node2 as it’s double the price. In fact using the node 2 playing hi Fi into my pre dac and then doing the same with the cyrus streamer playing hi Fi, the cyrus was better.
we did the same test using a meridian explorer 2 dac using a laptop and out using analogue into my pre dac, and again no difference with mqa to tidal cd quality hi Fi service. There was a slight difference to a downloaded hi res 24/192 file from hd tracks to the same mqa file off tidal masters, with the mqa track slightly better in hfs but not hugely so. But then the meridian is a miniature headphone type dac I think, so I’d expect this in my system.
Atm I think the bluesound node2 is one of only a few mqa capable dedicated budget type hi Fi streamers (or the only one?) without the full unpacking dac of streamers like the ps audio ones which are a lot more expensive. Conceivably id hear a good difference on a ps audio device or one of the really expensive meridian streamers using mqa, but a lot of cash it wouldn’t be worth it in my system for the yield ie paring £5k streamers with value of speakers etc.
Maybe you’d hear it on really good headphone amps and headphones, but again for me this is the ‘splitting hairs source argument’ in a hi Fi system. It’s always better in a hi Fi just to buy the best for sound quality in the component make up of the device, and not get hooked up on files and mqa unless you are playing really bad mp3s etc.
Node 2 doesn't do anything to MQA via digital output and passes it on as FLAC. No wonder it was the same.
I listened to MQA via Tidal desktop app which does half the encoding with Yamaha WXC-50 as a DAC. Compared against non MQA albums again from Tidal and the difference was not difficult to spot. It was like FIR filters or Dirac Live was being used. For those who used it will know what I mean.
