DAC or Network streamer
pGoff
Looking for some advice on setting up a music system for the lounge
The main source will be spotify and itunes and music stored on a NAS drive. Improved sound from the TV would be a bonus
I have a Pioneer A400 amp (old but sounds fine) + Celestion SL6 speakers + Apple TV
From my investigations so far I was thinking of buying a DAC such the Cambridge DACMAGIC100 and connecting it to the A400 - and feed it from the optical ouptut from the TV which has the Apple TV and NAS drive connected.
.......or would I be better buying a network streamer such as the Pioneer N50A feeding the A400
.......or an AV amp such as the Denon A2300 although I don't intend to have a surround set-up
I don't want to spend too much but will if the sound warrants it
Since you mentioned Pioneer I'd recommend Yamaha WXC-50 or even better a WXA-50 as an all in one solution. It should just about cover all you've mentioned and more.
What about something like an Onkyo TX-L20D - a stereo recever with HDMI for your telly, networking functionality, Spotify, Airplay, Google Cast, Tidal, Bluetooth etc. etc. Being a slimline receiver it will not be as bulky as most home theatre AV receivers.
Thanks for the replies - very useful - both are potential options
Has anyone auditioned the Yamaha / Onyko and the Denon A2300 (I've only heard the Yamaha which sounded good in a brief test)
I haven't hear the Yamaha WXA-50 but own WXC-50 (streamer preamp) and it's great. It's far superior in terms of ease of use than Pioneer which I briefly considered.
There is a cheaper option that would do what you want, personally I think its a good one if your wifi is good.
Buy an audio Chromecast, download an app called BubbleUpnp, you are pretty much sorted for 20 quid.
If you still feel you need a dac, have a look at some SMSL options on amazon. I have the M3 model and its the best 50 pounds I have ever spent on hifi. There are a few more options of better specced ones also. The m3 will also allow an android phone plug in directly and bypass the phone/tablet sound card as long as the device supports otg and is android 5 or newer
