The amp im currently using makes a popping noise, i contacted support and have to return it. So now im looking for a new dac and amp to use. im looking to spend about £300 but can spend a little more if it gets be something better
What are you currently using?The amp im currently using makes a popping noise, i contacted support and have to return it. So now im looking for a new dac and amp to use. im looking to spend about £300 but can spend a little more if it gets be something better
and if you meant what device am I using, it's a desktop PCi use tidal if that's what you mean, if you mean my current amp/dac them I've been using an ifi zen dac v2
thanks, just wondered what sort of inputs you required on the new amp / dac.and if you meant what device am I using, it's a desktop PC
ill take a look what topping has. as for why i dont want another ifi, although its probably just the unit that i received, but as this one was faulty i think id prefer getting something from someone else.thanks, just wondered what sort of inputs you required on the new amp / dac.
what's wrong with another iFi?
The Topping DX3 Pro might be worth a look, or the DX5 but thats £449
If it were me I would use separates but I think.your budget precludes this and you will probably be better off with a combo unitwould it be better to get separate amp and dacs, or to stick with a combo unit
That's something you will have to decide.how much would you recommend spending? bearing in mind that currently im only using a pair of HD660s
okay well thank you for your helpThat's something you will have to decide.
If you decided on the separates option then, for the amp, their A50S would be worth a look.ill take a look what topping has.
