Ben K. said:Hello Anyone know if cyrus 8 pre/power combo would be any good for monitor audio rx8? Thanks
FrankHarveyHiFi said:Can you elaborate? There is no 8 pre, only an 8 Power. The current pre-amps are the PreXpd and DACxp+. Or are you referring to using an 8xp integrated amplifier as a pre-amplifier?
MUSICRAFT said:Ben K. said:Hello Anyone know if cyrus 8 pre/power combo would be any good for monitor audio rx8? Thanks
Hi Ben K.
How would you describe the performance of your system?
What do you and anyone else who is also likely to use the system generally listen to?
The size of your room?
Your general listening level?
How is your system configured ie. crossover range for movie/multi channel soundtracks, for two channel use are the Silver RX8's on their own or with the RXW-12?
What areas of improvement are you looking for the Cyrus amplification to give you over the RX-V2065/RB1510 and the kind of presentation for the system to reproduce?
All the best
Rick @ Musicraft
Ben K. said:Hi My room is 17x14 foot with my speakers firing down the 17 foot. Generally I listen at medium to high volumes and listen to dance, hip hop, reggae and some pop. At the moment I listen to music with just the rx8's which are bi-amped using the rotel and rear channels of receiver. My system sounds good but a little more control in the bass and possibly a more open midrange would be good. I have heard the speakers with arcam amplification and liked it but the size of the cyrus equipment tempts me. For movies my system is as good as I want itMUSICRAFT said:Ben K. said:Hello Anyone know if cyrus 8 pre/power combo would be any good for monitor audio rx8? Thanks
Hi Ben K.
All the best
Rick @ MusicraftThanks
MUSICRAFT said:Ben K. said:Hi My room is 17x14 foot with my speakers firing down the 17 foot. Generally I listen at medium to high volumes and listen to dance, hip hop, reggae and some pop. At the moment I listen to music with just the rx8's which are bi-amped using the rotel and rear channels of receiver. My system sounds good but a little more control in the bass and possibly a more open midrange would be good. I have heard the speakers with arcam amplification and liked it but the size of the cyrus equipment tempts me. For movies my system is as good as I want itMUSICRAFT said:Ben K. said:Hello Anyone know if cyrus 8 pre/power combo would be any good for monitor audio rx8? Thanks
Hi Ben K.
All the best
Hi Ben K.
Thanks for your reply.
I am sorry if i am missing something but are you bi amping the RX8's with the RB-1510 driving the LF and the RX-V2065 driving the mid/HF?
All the best
Rick @ Musicraft
angelface59 said:ARCAM and Cyrus have a very different sound so I would take your speakers into your nearest Cyrus dealer before committing to buy.
If you have the money to buy an integrated amp and power amp at the same time I would go for a dedicated pre-amp rather than an integrated as it will sound better. Adding a power amp to an integrated amp is a good upgrade if you only have money for an integrated at the moment.
Would you consider second hand? There are loads of Cyrus boxes and relatively bargain prices on various sites. The big advantage is that if you dodn't like it you can sell on without too big a hit on your finances!
