Custom Cables
cheyworth
145
I am looking for some good quality cables to bi-amp my stereo speakers but only have one output on my pre-amp, can you get Y-cables or is it a custom made cable? if so from who?
Chris
John Duncan
2,034
30
19,720
Can't really be done - biamping (v1) depends on an integrated to provide the signal to the tweeter, and a power amp (fed by the integrated's preouts) to power the woofers. You could bridge the power amps to mono and use one for each speaker though (biamping v2).
I wouldn't go splitting the signal from the preamp to the power amps, you could run into all sorts of problems. There are a couple of preamps out there (IIRC) that have two sets of variable gain preouts to do just this, but your NAD ain't one of them.
