Custom Bracket Required
1978scotty
26
I am after a custom bracket but struggling to find someone to follow my design. Can anyone point me in the direction of a ccompany that will be able to make a bracket the way I want?
1978scotty
26
I have my screen on a cantilever bracket which gives flexibility for the variable seating. So now I want to hang a Yamaha YSP 3300 but the bars that I keep finding aren't strong enough to hold the YSP level so the bars flex and the YSP tilts slightly downwards which over time would only get worse. So I need something that is made from a stronger metal and a custom would provide this but at a cost
The purchase of the YSP was more for the quality of sound and opening the range. Given the location in the room reflecting sound hasnt really been successful but this doesnt bother me. Given the room layout we often use the pull and twist function of the cantilever and I would like to mount the YSP on a bracket attached to the cantilever bracket so the sound is always direct from the screen image.
Petherick
122
18,595
Where in the country are you? Most towns have at least one small engineering company and if they're any good they'll be able to interpret your design.
1978scotty
26
I am in Bishops Stortford Hertfordshire and the only ones I have found dont focus on something of this scale, i have also asked them for recommendations but so far no takers. Something so simple is proving rather awkward but I will get one way or another and then the trouble will have been worth it.
skippy
68
You could put an add in your local loot.
All you need is someone who has access to the gear to make your bracket. I used to work in the flour milling industry and used to make all sorts of frames, stands and supports.
Sounds like you need a friend of a friend who can take on your design :?
Petherick
122
18,595
Have you tried asking in Coopers in Stortford? They may know someone. Unfortunately I don't have any recommendations nearer than Cambridge.
If you could put your sketch or drawing on this forum maybe someone might take up the challenge - or if you want to email me a sketch and maybe a photo I could draw it up for you, if that helps.
