- Aug 22, 2007
- 82
- 0
- 0
Hi folks,
I have previously avoided Apple products like the plague, but now I feel ready to move over to the dark side
Only in a small way though, the product that has my attention is the AirPort express. I'm just looking for a way to stream music from my PC's to my hi-fi, without involving any games consoles!
I'm not terribly sure of the AirPort's compatibility and operation, so have a couple of questions if anyone would be so kind?
1-Does the Airport connect via your existing router, or does it connect directly to the PC you are streaming music from? I have a PC which is connected to my current router via ethernet cable rather than wireless, so I'm wondering if this would pose a problem? Apologies if this is a daft question, but it's late and I've been on too many Mac forums!
2-Can the AirPort receive music from various PC's, or just the one? I also have a (Windows) laptop connected to my router wirelessly.
3-Are there any official ways to control the system remotely? Or would I need something like Salling Clicker?
4-If I was planning to add several AirPort Express, in various rooms, would it be beneficial to replace my existing router with an Airport Extreme? Or would it be simpler to avoid Apple altogether and go the Squeezebox route?!
5-Are there any other DAC's I should be considering other that the Beresford (ie cheap!)
Thanking you kindly
Thanking you kindly
