Contact cleaning
cheyworth
145
What would you all reconmend to clean cables and sockets?
I have a few days off comming up, so I am planning a really good clean of my system. I will take everything out and clean, then put back.
I will be cleaning Phono cables and plugs as well speaker cable connections.
Chris
CnoEvil
556
14
If you want to throw money at it: Craig Deoxit.
Never tried it, so can't comment on it's effectiveness; but would be interested if anyone else has.
CnoEvil said:
If you want to throw money at it: Craig Deoxit. Never tried it, so can't comment on it's effectiveness; but would be interested if anyone else has.
Tried it, liked it. You can pick up a pack which contains the fluid and necessary cleaning cloths buds etc for about £13. I found i t to be very effective. Search for 'Caig Labs K-AS10 Lint Free Accessory Kit'
CnoEvil
556
14
Thx
RobinKidderminster
582
Suggest make new connections with clean wire where possible and petroleum jelly to prevent corrosion. Banana plugs make life easy.
chebby
1,257
34
19,220
Yes, soldered banana plugs where the newly exposed copper has been 'tinned' first.
bretty
248
I use this stuff:
£5.50 delivered. There's enough in the can to last a lifetime.
Link
Youre so cool! I dont suppose Ive learn anything like this before. So good to search out anyone with some unique ideas on this subject. realy thank you for beginning this up. this website is one thing that is wanted on the web, someone with a bit of originality. helpful job for bringing something new to the internet!
Vardenafil inheritor Discount tadalafil platinum
