Connecting Wharfedale D320 to PC
bonjurkes
I have Creative sound blaster z sound card on my PC and I was wondering if it's possible to connect D320 to my PC. Soundcard has 3.5mm input, and D320 has screw terminals. Would Sound Blaster Z's amp gives good enough power for D320 to work? Is it a good idea?
When you say the sound card has a3.5mm input, you mean output?
Unless the card has an output designed to power passive speakers, then it can't be connected directly to your Wharfedales.
