Connecting PS3 - Help Required
bf1
40
Would appreciate any help you can give with regards to the following:
I have a Panasonic PX80 TV, Sky HD, PS3, Nintendo Wii and Harman Kardon HS250 2.1 Home Cinema System.
The Sky, PS3 & HK250 are connected to the TV via HDMI. The Wii is connected to the TV via component leads.
The PS3 had an audio optical lead connected to the HK250 (there is only 1 optical input on the HK250) and the Sky box had the audio out connected to the HK250 via phono leads.
However, I kept getting a crackling / interference type noise whenever I watched Sky content and eventually resolved this by connecting the Sky box to the HK250 via the optical lead.
This means that I now have no sound from the PS3 and I'm not sure how to resolve this. I could buy an AV cable but this means I will not have HD quality output from the PS3.
Any ideas please?
bf1
40
I posted this on Home Cinema and have received a solution - run an optical lead from the PS3 to an Optical to Digital converter which has a coax out that can be plugged into the coax digital in on the Harman.
