Connecting M-CR603 to internet radio
tom2b
29
Afternoon all.
Apologies if this is posted in the wrong forum.
As the title suggests I am looking for advice on this. Is there a Simple way of connecting to internet radio without the need for cables,etc..? My M-CR is downstairs, I do have Internet access upstairs( via Virgin Media cabled access), and a Virgin media HD box downstairs.
Thank you for advice/suggestion
I use the Tunein Radio Pro app on my iPhone / iPad for any non BBC radio (otherwise I use BBC's iPlayer Radio app). Both via Airplay on my M-CR603.
Both apps are better (better GUI and better SQ) than d###ing around with some built-in internet radio function.
You can connect you MC-R603 with a wireless network using a so called Wifi-bridge (this converts the wifi-signal to wired ethernet). I use a TP-link WR702n. This is a travel router, but you can also use is as Wifi-bridge.
Make sure you install the last firmware from de TP-link website. It's a bit confusing to setup, but here it works like a charm...
