Connecting Denon DCD-425 CD player to a Denon AVRX2100W receiver.
agcdavison
I am trying to connect a Denon DCD-425 CD player to a Denon AVRX2100W receiver. I have a standard red/white audio cable, and am trying to use the 'CD' channel. But am unable to hear anything. I can get playback through the headphone jack so I know the CD player works. Can anyone advise what I may be doing wrong, or why I cannot hear any playback?
Gray
Assuming you hear other sources from the receiver's speakers,:
Double check both ends of your twin RCA lead connections - from CDP analogue out to receiver analogue line inputs .
Ensure the correct receiver source is selected etc.......
Say whether the receiver has (optical or coaxial) digital input(s) available to use.
nopiano
Is it the headphone jack on the CD player or the Denon that you’re listening to?
agcdavison
Are you using the input labelled 4 CD on the back of the Denon? Then selecting that input from the CD button on the remote?
Yes, using the 4 CD output, and yes, selecting CD from the remote. Problem was that I hadn't assigned the input to analog. Have done that now and it's working perfectly. Thank you for taking the time to help.
Reactions: nopiano
agcdavison
Discovered what the problem was...I hadn't assigned the input to analog. Have done that now and it's working perfectly. Thank you for taking the time to help.
agcdavison
I was using the line out on the rear of the machine and not getting any sound. But noticed that I was getting sound through the headphones. But I've now discovered what the problem was...I hadn't assigned the input to analog. Have done that now and it's working perfectly. Thank you for taking the time to help.
Reactions: nopiano
