- Aug 10, 2019
- 2,556
- 5
- 0
Hi Andrew, quick question for you!
I'm on the hunt for a massively better DVD player than I currently own (either a Marantz 9600 or a Denon 3930) and I'm guessing that their internal decoders are better than those in my Denon AVC A10SE. Therefore I'm planning to connect it via a fistfull of analogue cables to get the best sound possible.
If in the future I buy an HD player, my amp will only be able to play it's sound through multichannel analogue connectors and this leaves me wondering whether I'll be stuck or not!
Now, the Denon has 2 sets of multichannel inputs on it's very pert posterior! One is a 6 channel input for dolby 5.1 and the other is an 8 channel input for 7.1
If I use the 5.1 input will my amp still be able to matrix them into DTS ES or DD EX if I'm ever able to add the 2 channel power amp and pop a pair of speakers at the rear?
If I use the 7.1 input and only provide it with 5.1 inputs will the same be possible? Or by then will the HD players decode into 7.1 discreet channels?
Lastly, with both sets connected, they are switchable aren't they, as in not intended for use as an either/or just one input, but 2 seperate inputs?
Massive apologies in advance, couldn't have asked a nastier set of questions. Sorry!
